2003 Accord Automatic Transmission Shifting Problem
Old Dec 1, 2008 | 06:54 PM
jksharp's Avatar
Default 2003 Accord Automatic Transmission Shifting Problem
Hi,
I have a 2003 Accord EX V6 Sedan with the 5 speed automatic (103,xxx miles). Recently (maybe since it has gotten cold) the shift from 2nd to 3rd gear is preceeded by the rpms raising by a few hundred then it shifts. It's worse if i am trying to accelerate quickly. The fluid level is a little low, so i'm going to add some fluid. Could this be the problem? Any ideas or advice is appreciated.
Thanks,
Jackie
Old Dec 2, 2008 | 10:33 AM
Default RE: 2003 Accord Automatic Transmission Shifting Problem
welcome to the forum, has the transmission been serviced on a normal interval, like each 30k. the filter gets dirty after a lot of miles. Are you using the proper trans fluid. Hondas are sometimes particular of the fluids used. Then there is a relay on the transmission and this goes bad. May need a Helms or service manual for better info. Also can go to the Library for more info.
Munkhuu Saikh
Dec 6, 2015 12:39 AM
stephshonda
Aug 11, 2015 04:32 PM
benyesphil
Mar 29, 2013 10:56 AM
mrsalesco46
Jan 8, 2010 12:55 AM
scasper
Sep 30, 2008 10:34 PM
