2004 4 Cyl Accord Wont Start
Hi everyone,
I have an 04 Accord that wont start. There have been two times the past month or so when it was like -20 degrees out and I had to jump it to start. The other day, its like 40 degrees, and it wont start. I'm thinking, well it must be the battery. So I buy a new battery and that doesn't solve the issue either. I had the battery tested and its good--checked all the connections/grounds. All my dash lights/radio work. The wipers work, albeit a bit slow. Replaced the starter relay--still no luck. Any thoughts? Here's a video of what it's doing: https://streamable.com/yh1nr |
Make sure the posts are clean and the leads are tight. Does it make a clicking sound when the key is turned or do you hear nothing? |
Saw the video, it is a crank no start
Sounds like there is no compression. Please take oil refill cap off valve cover and check to see if the cams are moving when the engine is cranked over If the cams are not moving then suspect timing is off If the cams are moving then check for spark, fuel, etc. |
