2004 4 Cyl Accord Wont Start
Old Mar 17, 2019 | 08:22 PM
BigStuck's Avatar
Default 2004 4 Cyl Accord Wont Start
Hi everyone,
I have an 04 Accord that wont start. There have been two times the past month or so when it was like -20 degrees out and I had to jump it to start. The other day, its like 40 degrees, and it wont start. I'm thinking, well it must be the battery. So I buy a new battery and that doesn't solve the issue either. I had the battery tested and its good--checked all the connections/grounds. All my dash lights/radio work. The wipers work, albeit a bit slow. Replaced the starter relay--still no luck. Any thoughts? Here's a video of what it's doing: https://streamable.com/yh1nr
Old Mar 18, 2019 | 05:56 PM
Make sure the posts are clean and the leads are tight. Does it make a clicking sound when the key is turned or do you hear nothing?
Old Mar 18, 2019 | 10:29 PM
Saw the video, it is a crank no start
Sounds like there is no compression.
Please take oil refill cap off valve cover and check to see if the cams are moving when the engine is cranked over
If the cams are not moving then suspect timing is off
If the cams are moving then check for spark, fuel, etc.
AccordNYC
Sep 5, 2018 11:33 PM
bozobeebutler
Dec 26, 2016 07:52 PM
Falcon650L
Sep 2, 2013 05:36 PM
forevermemorable
Aug 26, 2013 08:26 PM
fastasf*ck21
Oct 7, 2007 05:21 PM
