2007 Honda Accord engine swap - to do or not to do?
Old Jul 15, 2015 | 02:42 PM
drgrein's Avatar
Unhappy 2007 Honda Accord engine swap - to do or not to do?
I have a 2007 Honda accord that had a used engine with 26,000 miles put in last October. In June of this year the timing chain slipped causing damage to the cylinder head. To have the head reworked it will cost $475 and I found a used engine with 176,000 miles for $355.
Damage is as follows:
1. Links on upper timing chain came off.
2. No. 1 cam yoke cracked at forward bolt.
3. Valve damage unknown at this time, but I'm sure there is some.
4. Head not off yet, so I am not sure about piston damage.
5. loose links may be at bottom of lower valve cover or dropped to oil pan.
My question is:
1. Should I take the head off the high mileage engine and put it on the low mileage block with a new timing chain and valve lash adjustment?
2. Just put the new timing chain I bought on the high mileage engine and adjust the valve lash and drop it in?
3. Just drop the high mileage engine in and hope for the best?
4. Can't throw a hail Mary or punt. I am running out of options!
This was such a great car, I would hate to give up on her, but cost is a huge factor!
Any suggestions are welcome. Work is starting Friday July 17th.
hokietiger
Apr 14, 2015 06:18 PM
Ravenous117
Mar 27, 2014 03:35 PM
Ricers 4 life
May 14, 2013 08:18 AM
peacemaker69
Jun 27, 2012 01:17 PM
96civic
Dec 8, 2008 07:27 PM
