2011 Accord code P0365
Old Feb 16, 2024 | 07:43 PM
tyty98's Avatar
Default 2011 Accord code P0365
Hoping someone can help me out.
i have a 2011 Accord EX with 3.5L V6 and the other day while driving back home my engine cut off and my engine light, oil light and battery light came on immediately and I ended up coasting to a side road fortunately. My car doesn’t turn on anymore it can turn over but the engine won’t turn on.
I ran a code on it and P0365 came up saying my B position Camshaft position sensor wasn’t working. Would that cause my car to not be able to turn on?
Im worried it can also have been my timing belt breaking off. Hoping that isn’t the case cause my and friend changed the timing belt ourselves back in march 2023 and I’d say I’m 100% sure we did it correctly when we changed it out. If anyone experienced this as well could you help point me in the right direction before I start throwing money at this.
i did end up pouring new oil into it which made the oil light to turn off. I also cleaned my battery and disconnected and reconnected the battery to try to reset the ECU. Idk someone told me to try that but to no success. I’m just hoping I just need to install a new sensor and not that my timing belt might’ve broken I haven’t checked to see if that’s the case cause of where it’s parked at and the weather.
Old Feb 16, 2024 | 08:55 PM
Why not take the cover off and see, Sounds like it may have jumped.
Does the engine sound normal while cranking?
StManson
Dec 14, 2020 11:07 PM
sunnysioux
Jul 22, 2019 03:50 AM
HondaMan44
Oct 27, 2015 03:11 PM
Sam Abrams
Oct 24, 2015 06:44 PM
samuel_gatech
Nov 4, 2009 04:46 AM
