2014 Accord V6 P0 420
Old Nov 13, 2021 | 12:43 PM
Dent Man Dave's Avatar
Default 2014 Accord V6 P0 420
Hi, new to this forum with a 2014 Accord EX L. Only had it a month and it just threw a P0 420 code, Cat Converter ( or 02 sensor?).Car runs great, good mileage lots of power, smooth shifts, all seems good but for this code. Anyone have any good thoughts? Car has 165,00 miles,Thanks in advance, Dave
Old Nov 13, 2021 | 08:33 PM
welcome to the forum had a similar experience on my 06 Fit. had 230k miles cat code showed, had the shop check and reset. ran car for another month, same code. changed cat 1400.00 now no codes. current miles 295k miles.
Old Nov 14, 2021 | 12:34 AM
Dreaded P0420. Cat below efficiency
Could be the cat or could be the O2 sensor??
My nephew's CRV has that code
NYS has Cali emissions regulations. So need CARB approved cat.
Expensive!! $2350 at the dealership
Found on line for $1600.
Cleared codes and watched the readiness monitors.
When it was almost complete, went in for inspection. Passed.
So, got another year before having to change out the cat.
Old Nov 24, 2021 | 02:51 PM
Well, the code is still there but the light is out. Mechanic said that means it's pending but should be fine just drive it and watch. So I guess that's what i'll do.
Old Nov 24, 2021 | 11:12 PM
Does your place have annual inspections?
Do you have a code reader?
If you do then you may be able to see the pending code list?
Have you ever changed the spark plugs?
Old Nov 25, 2021 | 01:50 AM
Default P0420
I have a scanner and it shows the code as pending. It seems to stay at pending. The engine just had a recall done ( Bank 1 cylinder rings) Also at that time had timing belt & accessories done plugs too. It seems that it won't be a problem for emissions unless it triggers the MIL. I guess i'll just wait it out and see. The mechanic seems to think that it may resolve since the recall problem may have allowed excessive oil through the cat
Old Nov 25, 2021 | 09:04 PM
If you do not have an inspection soon then try clearing or erasing the DTCs and see if the code returns (pending or other wise)
Would think that you do not have a serious issue and hopefully everything is back to normal.
Old Dec 20, 2021 | 04:45 PM
Well, following one suggestion I've run several tanks through with Techron in each tank and no codes. Scanner shows all green. May just be a fluke or coincidence but I'm happy.
Old Dec 21, 2021 | 12:35 AM
Good news.
Thanks for the update.
Hope it stays healthy and goes for a few more years without trouble.
Old Jan 10, 2022 | 06:03 PM
  #10
Me Too! I love this car. My 4th Accord
Blues_Junkie
Aug 22, 2019 10:40 PM
millertimegooney
Mar 28, 2016 11:11 AM
in2puck
Jul 17, 2014 07:17 PM
mrzip
Mar 2, 2014 09:22 PM
trev0006
Aug 19, 2013 01:35 PM
