2014 Battery Drain
Old May 6, 2019 | 05:05 PM
2004Accord's Avatar
Default 2014 Battery Drain
Date 5-6-19 - replaced Battery ~ 2.5 years ago via dealer. Replaced battery just yesterday. Battery draining again after sitting. Youtube shows a common honda fix is to replace the Genuine Honda Power AC Relay Assembly. Do any of you have this problem, please provide links, feedback
You tube say I need to replace the AC relay fuse. so i tested the horn - it works - pulled that relay. Pulled the relay for the ac. Place the ac realy in the horn position( same relays) and the horen worked. So I am bit confident that the AC relay is not the issue.
I have some kind of parasitic battery drain. I cant figure it out.
Old May 6, 2019 | 10:31 PM
Old May 7, 2019 | 07:34 PM
Good vid
dunkindan2
Jun 28, 2019 06:34 PM
14Clarity
Dec 7, 2018 04:31 PM
butterbean65
Dec 31, 2012 01:44 PM
t-dogg
Aug 16, 2009 10:47 AM
johnnygr22
Mar 18, 2009 10:33 PM
