2020 Accord Radar Unit
Old Apr 22, 2022 | 03:34 PM
skoll's Avatar
Default 2020 Accord Radar Unit
I'm currently in the middle of my 2020 Accord EX-L repair works and the last part I'm missing at the moment is the radar assembly. The item code is 36803-TVC-A16 / 36803-TVC-A17. The problem is that it is out of stock both new and used across the entire USA.
I have contacted multiple service centers and dealerships, ordered it three times already but every time just got my money back after a while since they didn't actually have this part anywhere.
RIght now I'm being told the part is in the global US backorder without any ETA from Honda on when will it be delivered. The only thing I can do is to wait as per what they say. And this lasts for almost 5 months already since I initially ordered it so I have no clue how long will it take to just keep waiting.
So my question is: is there any backward compatibility with other similar radar units (from different trims, 1.5L models, etc.) or is there a way to adjust the radar software in order to make it work? There is plenty of other really similar radar units but since they are usually somewhat around 600$ I don't want to risk bying them blindly.
I was also asking the dealerships about those similar models (e.g. 36803-TVA-A27) and they can't guarantee anything.
Any clue on where can it be found new or used would also be a great help.
Thanks in advance!
Old Apr 25, 2022 | 09:46 AM
ALEX152's Avatar
i have the same problem with the same part nummber 36803-tva-a27
have not been able to resolve the issue
Old Apr 25, 2022 | 02:52 PM
skoll's Avatar
I don't know if this info can help you but anyway.
1. As I can see by the part code this is a hybrid 2.0 you are looking for a radar for. We have tested a 1.5L radar on a 2.0T car a couple of days ago and no luck - it says the radar is incompatible. Though we had no chance to test with the radars for the same engine and transmission but a different trim - this might have worked. In case you will have a chance to try tris yourself please share your experience here.
2. I've contacted some dealerships again, they say the current backorder is quite huge for all Accord radars. The closest arrival for mine is expected in June, for the rest of the models it is pretty similar.
Old Apr 25, 2022 | 02:56 PM
skoll's Avatar
Also have you maybe managed to make the car run without the radar.
I mean having adaptive cruise control and other honda sensing features is not a problem in a short term and we could use the car without them.
But in our case the gearbox is in some "emergency mode" disallowing to accellerate, ESP is off as well.
I beleieve there should be a solution to get rid of most of those symptoms since they should not be physically dependant on the radar absence.
Old Apr 28, 2022 | 08:46 PM
C 10 man's Avatar
Banned
Thanks in advance!
For that reason is why Used Cars and Trucks are SO EXPENSIVE. Our 2014 Camry I was told is worth $14,000 now because of the newer Vehicles PROBLEMS.
good luck with your problem.
Old May 5, 2022 | 10:30 AM
skoll's Avatar
Thank you!
At the end I have finally managed to solve the issue seems like.
For anyone else with the same problem the solution is to place an order somewhere just to be in a queue (though they might charge you a fee of 10-15% of the order value in case of cancellation if the parts were ordered for you and were not in stock)
In parallel I was constantly checking car-part.com website. This is the root UI of a CRM all used cars marketplaces use. So when you use the same UI on their site it will only list their own parts but searching using this "main" site gives you the listings of all used parts sellers.
So one day the desired radar just appeared there. The interesting thing is that there were 5 sellers for this part all with different prices. As I understood the lowest price is the original seller and the rest are resellers who never owned this part and just want to get the margin out of it. So consider contacting the lowest price seller.
I'm now waiting for the part to be shipped so the mission is almost completed, yaaay.
Old Sep 20, 2022 | 03:10 AM
Sultan's Avatar
Dear skoll,
I have the same problem as you. I also have a Honda Accord, the only difference is that mine is a 2018 model.
Have you received the item since your last post? Do you live in the USA?
Do you have any recommendations where I could find one? I checked car-parts.com, but haven't succeeded so far.
I'm located in Hungary, Europe. However, I have a friend in Washington (20132) so I could order the part to his place and he could forward it to me to Hungary.
Thank you for your help in advance, I'm grateful for any tips or information. My e-mail address is: szilagyi.zolika72@gmail.com.
Best wishes,
Zoltán
Old May 14, 2024 | 12:26 PM
skoll's Avatar
Hey Zoltán!
Really sorry to hear you're facing the same issue too.
I had a lot of "fun" truing to purchase it online. Though as I can see right now there are options for sale in the US.
I'm not sure about car-parts.com - never used it. Though car-part.com is a completely different thing.
I can see there are radar units for your Honda are actually in stock (e.g. for $195 in New Mexico). This site allows car disassemblies to sell their parts which is great and you can also chat with them online via this site. Though it is very important to have a person there (u're lucky you got one) since they are SUPER conservative there, only aoow wire transfers and your delivery address should fully match your card's billing address. I was trying to order it through a delivery company and got a cancellation and a refund like 5 times.
In car-part.com make sure you select "camera projector" as a part and a "radar unit, front (behind grille), turbo, 2.0L, AT, EX-L (leather)" on a final search step.
There is at least one seller there which fully matches your request
They will highly likely require a wire transfer and your billing address should be identical to your delivery address and it should all be within the US. Otherwise they will just cancel eveything and will never ship a single part for sure.
Hope this helps!
BradW
Mar 22, 2021 04:39 AM
JP29
Jul 26, 2020 08:40 PM
SoCalDave
Jul 5, 2020 10:08 AM
MCC555
Feb 21, 2020 10:42 AM
