90 Honda Accord Tranny
Old Sep 14, 2007 | 11:19 PM
chas638's Avatar
Default 90 Honda Accord Tranny
I have a 1990 Honda Accord. Driving the other day and the sport mode light went on and the car doesn't shift. It starts off in 3rd gear. If I downshift to 1st, it will start in first but when I upshift it goes right into 3rd bypassing 2nd but not overdrive 4th. Did anyone else have this problem and do I need another transmission? The other thing is during cold weather, I have a hard time getting the key out. If I wait a couple of minutes, I hear what sounds like a click and the key can be removed. I love this old Honda but don't want to pay for a new tranny that would cost more than the car is worth.
Old Jan 28, 2008 | 05:02 PM
prettibwoy's Avatar
Default RE: 90 Honda Accord Tranny
any info on this topic i am experiencing the same thing . but my tranny is just letting my engine rev really high as it drives off very slow???? help pleaseeeeeeeeeeeeeee
Old Jan 29, 2008 | 03:55 AM
Aloha prettibwoy: welcome to the forum and enjoy your stay, hope we might all be able to assist you with your problem. might be your shift control solenoid. Do you have a repair manual? Helms, Chilton, or factory, it may help to have one, it will give you more info. or go to the local library, they usually have the manuals.
Old May 22, 2008 | 08:43 PM
johnwiltfongjr's Avatar
I had the same problem in my 92 LX. I replace the entire transmission first...no luck...I replaced the TCU....worked for a bit then stopped. It started throwing codes and I had to replace a solenoid on the front of the transmission. It was clogged as they operate on the pressure from the fluid. It still didnt run 100% in that it shifted really hard though. Trannys are tricky things.
Old Jun 6, 2009 | 11:43 PM
rxrkc's Avatar
Our 1990 Honda Accord LX automatic transmission has shift problems. Starts off in 3rd. I can manually shift in 1st to start off & manual shift to 3rd. No 2nd or 4th speeds on automatic transmission, also sport light not functioning correctly.
So we're looking into getting our mechanic to put on a set of transmission shift solenoids. We found guaranteed solenoid parts on e-bay for about $60 & then one hour labor for mechanic to install should hopefully solve the shifting problem for about $130
tivo
Nov 15, 2014 07:54 PM
hondahomie
Dec 9, 2012 08:21 PM
baritus
Feb 26, 2010 02:27 AM
ocruz96
Feb 1, 2008 03:01 PM
fondario
Jun 15, 2007 04:32 PM
