91 Accord, fixer upper
Old Jan 13, 2014 | 11:15 AM
andymccauley's Avatar
Default 91 Accord, fixer upper
Just picked up a 4 banger auto for my gf yesterday. Seems to run pretty good. Just from getting in the car I could tell it needed a motor mount, check fuses because the windows don't roll down, and it needs brakes due to warped rotors.
There is no muffler from the midpipe back, I have a fart can for it though. If I need help I will come here. Im New top Honda but not cars I'll post pics soon
Old Jan 13, 2014 | 06:52 PM
Welcome in.
Old Jan 14, 2014 | 10:29 PM
here is my complete list....
Tube seals were puking, plug wires looked original or close to it, bad motor mount, warped rotors/bad caliper (haven't pulled it apart yet), bypassed power window relay, D4 light is flashing was going to check the code today but didnt get to it, needs at least 2 tires and maybe tire rods with alignment or maybe a rack (again haven't checked yet), no muffler from the midpipe back, large cracks in the drive belts.
Whoever owned the car before the 18 year old we bought it from wrote the T-belt had been done at 73Kish on the inner fender with paint marker. I want to do the T-belt soon, I pulled the timing cover back and the belt didn't look terrible but you never know.
Today I replaced the valve cover gasket, spark plugs, plug wire, cap and rotor. Learned the battery terminals were loose and after I changed all that the car wouldn't start Runs alot better thats for sure.
Old Jan 19, 2014 | 11:04 PM
Some Pics!
This is where the exhaust ended when we got it.
This is what I pieced together today with a fart can I had laying around from a 720 I parted out.
Old Jan 19, 2014 | 11:06 PM
Checked the code for the trans and it also had a stored CEL
Trans - #2 Lock up shift solenoid from what Ive read on another site. At a glance on google a new one is $250, not trying to spend that money yet.
CEL - #43 Fuel delivery issue. Been told its a bad O2 sensor, just trying to get a second opinion.
Soooo after the tune up a hard start issue in the morning started almost like it was starving for fuel. Then replaced the fuel filter, burned some seafoam through the intake and added some to the gas tank no change. Kinda stumped.
still need to get drive belts and an alignment, got 2 tires the other day, and will be pulling the distributor apart soon to replace the inner seal and the O-ring in the head.
Old Oct 5, 2014 | 10:54 PM
SOOOO just ordered front wheel bearings, rotors, pads, upper/lower balljoints, front motor mount, and torque strut.
The mounts are cake Ive done those before. I have a few things on the brakes/balljoints that I have questions about.
1. Any advice on the wheel bearing replacement? I watched Eric the car guys video about them and Ive cut outter races off VW hubs before so thats nothing new. Anything I should be aware of? Ive replaced a lot of Subaru Wheel bearings so Im not new to this just dont have access to a good press, but I do to a Sh!tty one.
2. Know of a good cheap balljoint clamp/press or a good way to fabricate one? saw one on Amazon for like $45 shipped but dunno if it will do the job without breaking..
Since I posted this a LOOOOONG time ago there has been a idle issue that this car has been having. Its only on Cold start up the idle drops down to nearly nothing until it starts to get warm after warm it idles fine. Occasionally will die on start up too but it is very rare after not starting it for a few days.
I replaced the T-belt, Water pump, all the shaft seals, T-belt tensioners, drive belts, coolant temp sensor, 02 sensor, and replaced the Distributor shaft seal and o-ring.
This issue started after replacing the spark plugs and wires, didnt change after I replaced all of that other stuff. Well got a little better after I change the coolant temp sensor. Ive played with the Idle speed screw on the throttle body and increased the idle but still takes awhile to get past the low idle when cold.
A "Honda" guy I work with said these cars have issues with the throttle body and could be the issue but Ive never read anything about that and I imagine it would throw a CEL but maybe not.
1989prelude
Apr 1, 2015 10:41 AM
sferrie
Feb 24, 2012 09:26 AM
BombSquad91
Jun 29, 2011 01:35 PM
Kushla
Jun 20, 2007 01:24 PM
paulorlo
Nov 29, 2006 07:13 PM
