92 accord died while driving
Old May 17, 2009 | 09:12 AM
sadbuttrue08's Avatar
Default 92 accord died while driving
took the valve cover off and made sure the timing belt did not break it was good. checked fuel pressure its good. check for spark none. im not getting any spark at the coil. replaced the coil still nothing. there is 12 volts at the connector that plugs into the coil. idk what going on
Old May 24, 2009 | 08:49 PM
welcome to the forum, it could be ignitor unit, main relay or ecu if coil is good and the distributor and rotor are good. if you go to autozone.com and register for free, you can go to repair and it will give you info to help you.
qdog1965
Mar 13, 2011 01:17 PM
rufryder
Feb 6, 2010 02:31 AM
Sharjite
May 25, 2008 03:52 PM
nighthawk5556
Apr 27, 2008 01:14 PM
largoent
Apr 11, 2007 11:53 AM
