94 Accord ATF Change
Old Dec 12, 2012 | 10:45 AM
trailshredder's Avatar
Default 94 Accord ATF Change
Bought a 94 accord for my daughters first car. Going to change the ATF and use DW1. With me not knowing if/when/or type of fluid currently in there I am considering doing the drain/refill 3 times like I have been reading about. Is this truly the recommended way? If so, how far should I drive after the first and second drain/refill? Is the purpose to just keep diluting the old fluid, so all that really needs done is "mixing" it up? Thanks!
Old Dec 12, 2012 | 06:03 PM
lowlife9's Avatar
the purpose is to get all the old fluid in the torque converter out because about 70% of the fluid is in there. first shift through gears a couple times then drive around for a couple miles and repeat. the drain and fill is recommended by honda so i wouldn't doubt the recommendation of the company that made the transmission.the only other option is to use a pressurized machine which is not recommended because it can potentially cause problems with older worn transmissions.
Old Dec 13, 2012 | 08:04 AM
Yea with the flush method you won't get a new filter install.
Old Dec 13, 2012 | 04:37 PM
lowlife9's Avatar
i believe the filter is inside the transmission and cannot be replaced under normal circumstance. but you can ad a separate external filter.not having a easily replaceable filter is the main reason honda transmissions usually prematurely fail due to clogging.
popomama
Nov 22, 2018 08:25 AM
joepcr64
Jan 6, 2014 07:12 PM
ricosuave55
May 27, 2009 10:19 PM
Tacoboy
Apr 5, 2009 11:45 AM
brian_dev
May 5, 2006 01:52 AM
