94 Accord Drivers Window Problem
The Driver’s side window in my 94 Accord will not go up and down completely without manual assistance. Any ideas? Is it more likely the motor or the tracking? Thanks |
wlecome to the forum. remove the door panel and check the tracking, make sure the cushion tracks are in place and did not slide down. check the attachment near the bottom for loose parts, lube the cushion tracks with wd-40 to see if it helps, if all good, motor starting to go weak. make sure the electrical connections are clean or clean them. 94 parts are getting older. ( 24 yrs and still running. good car.)
Thanks
Thanks
Originally Posted by acmech52
(Post 31655)
Welcome in,I had the same problem with my 2000 Accord ,tried several things but ended up being the regulator ,hope that's not your case,good luck. |
