94 Accord Drivers Window Problem
Old Nov 19, 2018 | 03:46 PM
mellomain1996@gmail.com's Avatar
Default 94 Accord Drivers Window Problem
The Driver’s side window in my 94 Accord will not go up and down completely without manual assistance. Any ideas? Is it more likely the motor or the tracking?
Thanks
Old Nov 19, 2018 | 09:06 PM
wlecome to the forum. remove the door panel and check the tracking, make sure the cushion tracks are in place and did not slide down. check the attachment near the bottom for loose parts, lube the cushion tracks with wd-40 to see if it helps, if all good, motor starting to go weak. make sure the electrical connections are clean or clean them. 94 parts are getting older. ( 24 yrs and still running. good car.)
Old Nov 20, 2018 | 09:36 AM
Default Thanks
Thanks
Old Nov 22, 2018 | 08:05 AM
Welcome in,I had the same problem with my 2000 Accord ,tried several things but ended up being the regulator ,hope that's not your case,good luck.
ragu23
Jun 2, 2018 12:19 AM
Shawn_M_23
Feb 5, 2013 01:02 PM
rthawley2
Feb 11, 2011 02:47 PM
Valertyler04
Nov 2, 2010 12:49 AM
veloman
Apr 29, 2009 10:09 PM
