94 honda accord want start
Old Sep 7, 2010 | 05:35 PM
brian33's Avatar
Default 94 honda accord want start
3 days ago took the battery out to use on my boat.Then yesterday when i but it back in it would not start radio.lights ever thing works find just want turn over with the key it's like the cables are off.The battery is fully charge i can roll it a crank it with the clutch but not the key.never had any problem with starter or anything.is their any fuses that could have blowen or some kind of reset button i've tooking the battery out several times before but all ways crank up this is the first time it's ever happen.any ideals
Old Sep 8, 2010 | 02:35 AM
welcome to the forum. did you check to see that the terminals on the battery and the ones connected to the batt are brushed clean with good connection? then check your fuses in the engine compartment.
Old Sep 15, 2010 | 12:54 AM
hugh36's Avatar
Hello and welcome to the site.Its good to know you.have a great time and enjoy your stay here.
Old Sep 17, 2010 | 08:23 AM
That is strange,take a screwdriver and get under the car, cross the two terminals on the starter,it should turn over,but by all means chock the wheels and leave it out of gear first.If it turns over its a relay.If not it' s a starter,pull it off and go to Advance auto parts and let them check it.
Old Jun 14, 2012 | 08:41 AM
vipercarcom's Avatar
You said you used the battery on your boat. Can no longer current in it, trying to load a battery charger and then to start her car
hondaradford
Apr 4, 2013 08:07 AM
dazed
Aug 28, 2009 08:49 PM
tjalaska
Oct 16, 2008 08:59 AM
fastasf*ck21
Dec 9, 2007 05:15 PM
highwayman
Mar 15, 2007 11:41 AM
