-   -   95 coolant temp sensor vtec motor (https://hondaforum.com/forum/honda-accord-forum-11/95-coolant-temp-sensor-vtec-motor-2558/)
fastcar May 25, 2008 09:59 PM
replaced above about month ago. Temp gauge hovers near red if sitting in traffic on hot day. Fans will not come on unless ac is on.
Any suggestions?
acmech52 May 25, 2008 11:47 PM
RE: 95 coolant temp sensor vtec motor
are you positive that 2 fans go on when the a/c is turned on, I beleive only one fan of 2 goes on with the a/c on, the other fan is suppose to come on when the water temp gets to approx 210. Check from a cold engine start and watch the temp. approx 3/4 hot, one fan is suppose to come on. if not the temp sensor is not completing the circuit to give pwr to turn the fan on, or the fan motor is burnt out. Please check from cold and come back with the results.
fastcar May 27, 2008 05:45 PM
-OK if ac is off temp gauge goes to red area in matter of minutes no fans.
-turn ac on and both fans activate immediately
I drove around 4mos with gauge not working and i could always hear and feel motor drag with defective sensor. Since buying temp sensor from Advance Auto this start happening.
Maybe i should purchase Honda part and seethe results
Correct part is temp sending gauge switch
acmech52 May 28, 2008 06:34 AM
now i know that your fan motors are good, the thermostate sending unit is not allowing the power to the fan motor to turn on. check the thermostate sending unit to see if you have power at it. if you do have power the unit is no good. when temp gets to approx 210 the thermostate sending unit opens and continues the power to the fan to turn on and cool the rad temp down. (temp sensor might be the same unit.)
fastcar May 31, 2008 12:11 PM
&nbsp\\;Advance sold me wrong part. &nbsp\\; Autozone had it listed as Coolant fan switch part#TU197. <BR><BR>Thanks
