97 2.2 l 4 cylinder lx help
Old Jul 30, 2020 | 08:44 AM
John Thomas's Avatar
Default 97 2.2 l 4 cylinder lx help
I recently acquired this car it had an distributor seal leak after new seal plugs and battery ,starter its cranking and getting fuel and spark but it will not start even with starting fluid it set in his drive way for 2 years I've got to replace the alternator could there be something obstruction in the exhaust? It was out in the country
Old Jul 30, 2020 | 02:23 PM
Vehicles sitting for long periods of time will sometimes have little critters invade and nest in the vehicle.
However, should go through the basics.
Spark at the plugs
Fuel .. fuel pump, fuel pressure, fuel injectors and injector pulse
Compression
Timing
Air .. check filters
Exhaust .. obstruction?
If the distributor was disturbed then it may need to be readjusted?? Timing
Old Aug 16, 2020 | 11:38 AM
Default gas tank
I need to get the fuel out of the gas tank I've got an hand pump siphon is this the best way or would dropping the tank be faster?
Old Aug 16, 2020 | 04:19 PM
Hand pump siphon is the easiest.
Dropping the fuel tank would require raising the vehicle
And then having to deal with rusty nuts and bolts which is a whole 'nother can of worms.
Did you ever get the engine started?
What was the fix?
Old Oct 2, 2020 | 12:00 AM
Default Re
What was the fix?
I bought an Chilton's book for it and found most honda tanks have a drain plug
gets good spark and its pumping fuel
Still not running so I've ordered s new set of injecter s for it just waiting for them
Old Oct 2, 2020 | 07:22 AM
If you tried using starter fluid and it did not work then probably not fuel system related
Zman15
Mar 10, 2020 03:57 PM
Mcronin123
Nov 7, 2018 09:22 PM
Salyersman85
Mar 21, 2016 11:04 AM
Rededdedone
Mar 29, 2014 05:22 PM
Gsrfien
Feb 26, 2012 06:11 PM
