99 accord tailight problems
Old Nov 28, 2006 | 07:25 PM
david_leru's Avatar
Default 99 accord tailight problems
Please Help!! My left blinker will not work when my headlights are on, and the blinker indicator remains lighted if the headlights are on. The right blinker works however. If my lights are off, the blinker works like normal. I have already replaced the proper fuses and bought new bulbs as well as a new flasher.
Before I bring this to a shop, does anyone have any answeres??
Old Jan 6, 2007 | 04:52 PM
kornfox's Avatar
Member
Default RE: 99 accord tailight problems
Have you solved this problem? On my 99 Nissan Maxima Ihad the same problem. It was because my nissan has a turning light. Its a light that stays on when your blinker is activated to give you a little bit more light on the side that you are turning towards. If that light is burned out, your blinker will stay on. Thats why it only happens when the headlights are on. The turning light only works with headlights on. Hope that helps. Good luck.
900hp4dog
Nov 25, 2014 04:17 PM
J.Riv
Jul 2, 2010 09:49 AM
