99 Accord, tons of ODB-II codes
Old Jun 22, 2013 | 03:01 PM
Justin Abram's Avatar
Default 99 Accord, tons of ODB-II codes
Hey guys,
I have a '99 Accord VTEC 2.3 and when driving, it lags when accelerating.
I hooked up my ODB and got
P1361 Top Dead Center (TDC) Sensor Intermittent Interruption
P1259 VTEC System Malfunction
P0141 Secondary Heated Oxygen Sensor (Secondary HO2S) (Sensor 2) Heater Circuit Malfunction
P0301 No. 1 Cylinder Misfire
P0302 No. 2 Cylinder Misfire
P0303 No. 3 Cylinder Misfire
P0304 No. 4 Cylinder Misfire
From what I have looked up so far I think all of this is stemming from the same problem(s) but I just wanted to see if anyone has had similar problems with this many codes and see what you guys did.
Thanks for the help!
Old Jun 22, 2013 | 03:05 PM
OBD, sorry, I'm a little dyslexic
Old Jun 22, 2013 | 09:12 PM
lowlife9's Avatar
P1361 is: Intermittent Interruption In TDC 1 Sensor Circuit Check the out the TDC sensor, connector 124 (gray and on the distributor) check power and grounds. It's missing signal from the TDC sensor in the distributor and causing a misfire. its intermittent so it probably bad wiring or the sensor needs replacement replace your secondary oxygen sensor and remove and clean your vtec Solenoid
rdriscoll36
Jun 26, 2013 05:42 PM
Meals
Dec 20, 2008 03:43 AM
juicy629
Jul 12, 2007 03:17 PM
stdeclipse
Sep 28, 2006 09:37 PM
HVAC
Apr 12, 2006 11:44 AM
