Accord 2000 90K service
Old 10-25-2009 | 06:22 PM
writehaseeb's Avatar
Default Accord 2000 90K service
Hi folks,
New here and need advise. I am coming on my 90K service and want to know what major things to looks for and IMP ones that cant be overlooked.
Old 10-25-2009 | 10:21 PM
welcome to the forum. transmission and radiator flush, cabin filter, air filter oil and filter, wheel alignment, brake check. If you go to Honda"s official site, you and register for free and theree willl be a service check list available to see what can be done or needs to be done.
Old 10-26-2009 | 04:12 AM
Thanks what about:
brake fluid, timing belt, water pump, oil seals, and drive belts???
Also I just replaced all 4 pads on my car and the guy also resurfaced all 4 rotors and charged me 180 front and 180 back??? do u think pads+resurfacing rotors+labor 360 is reasonable?
Old 10-26-2009 | 08:45 PM
brake fluid flush is good, timing belt it 105k or 7 year, so timing belt water pump and crank seals are all in the same area.
Brakes for the front for 180 is a bit on the high side, have you done some shopping. I do my own brakes, so its a lot less. I replace my rotors (Brenbow) and pads thermal quiet cost at 150.00 and about 2.5 hrs. The shop I went to did my fronts for 120.00, stock brakes and turn the rotor. Timing belt change with all the other parts can get costly, You need to do a bit of shopping.
Old 11-15-2009 | 09:13 PM
Guy honda is quoting me 542 for a 90K service that includes:
transmission FLUSH
brake FLUSH
air filter
cabin filter
engine oil and filter
drive belt inspection
tire rotation if required
balancing if required
and some other checks ... COOLANT is not included ...
Please advise?
Old 12-04-2009 | 10:29 AM
D.hieme's Avatar
its impossile even if the price go 199 all will buy honda accord
chiliuch
10-13-2022 09:57 PM
salsaman06
11-29-2014 06:17 PM
Mike Artz
12-18-2012 01:57 PM
vacuuum
12-29-2006 05:45 AM
Prince
06-16-2006 03:45 PM
