90K maintenance on 97 accord
Old Dec 17, 2012 | 06:13 PM
Mike Artz's Avatar
Default 90K maintenance on 97 accord
For the 90K maintenace on my 6 cyl 1997 Accord I changed the plugs, plug wires, distributor cap and rotor. Also, flushed coolant and changed brake fluid and trans fluid. At 70K a new timing belt was put in. Is this enough for 90K maintenance?
Old Dec 18, 2012 | 07:09 AM
Welcome in,you pretty much covered it between the 70K and 90K,here is what should be in your owners manual.
90,000 Miles
  • Change brake fluid.
  • Replace air cleaner element.
  • Replace spark plugs.
  • Replace drive belts.
  • Change transmission fluid.
Old Dec 18, 2012 | 12:57 PM
Mike Artz's Avatar
Thx bucwheat. I guess I got lucky and I don't have to adjust the valves. When I looked it up the 97 accord valves were hydraulic and don't need to be adjusted.
steve102
Jan 18, 2014 03:22 PM
dgalati000
Feb 5, 2010 11:30 AM
writehaseeb
Dec 4, 2009 09:29 AM
sidearm17
Jan 6, 2007 05:19 PM
hd3
Nov 15, 2006 12:56 AM
