break light problems
Right side brake light isn't working. I have power and ground, but the right side is still not lighting up. Any suggestions would be appreciated.
is the bulb burnt out ???. check the wires make sure there not frayed or damaged. check and clean all connections.
Some times a bulb may look good but is not, replace it anyway .Like Lowlife says clean contacts with a small piece of sand paper.
Hi Solomand3r
You should get it replaced if your brake lights and damaged or not working.There are many online stores that provide lights for the car. While browsing the net i came across http://www.xtralights.com/. It is having variety of Lights for the cars. |
Replace the lights or go to nearby mechanic shop they will help you out.I always to go my mechanic and he tell me the best way to get out of the problem.
motor vehicle technician |
Just replace the bulb ,it's cheap,if no brake light then check the socket,there maybe carrosion and a quick cleaning of the contacts will help.
