break light problems
Old Dec 10, 2012 | 01:17 PM
S0L0MAND3R's Avatar
Default break light problems
Right side brake light isn't working. I have power and ground, but the right side is still not lighting up. Any suggestions would be appreciated.
Old Dec 10, 2012 | 06:37 PM
lowlife9's Avatar
is the bulb burnt out ???. check the wires make sure there not frayed or damaged. check and clean all connections.
Old Dec 11, 2012 | 08:11 AM
Some times a bulb may look good but is not, replace it anyway .Like Lowlife says clean contacts with a small piece of sand paper.
Old Jul 18, 2013 | 05:09 AM
Rose Frankie's Avatar
Hi Solomand3r
You should get it replaced if your brake lights and damaged or not working.There are many online stores that provide lights for the car. While browsing the net i came across http://www.xtralights.com/. It is having variety of Lights for the cars.
Old Jul 22, 2013 | 01:29 AM
EleniBHernandez's Avatar
Replace the lights or go to nearby mechanic shop they will help you out.I always to go my mechanic and he tell me the best way to get out of the problem.
motor vehicle technician
Old Jul 22, 2013 | 09:04 AM
Just replace the bulb ,it's cheap,if no brake light then check the socket,there maybe carrosion and a quick cleaning of the contacts will help.
popomama
Nov 22, 2018 08:25 AM
Marc
Feb 25, 2013 11:25 AM
gamajohn
Sep 21, 2012 01:28 PM
coolgoose
Feb 23, 2010 01:26 PM
antbegone
May 10, 2008 03:26 PM
