Sponsored by:
Sponsored by:
97 vtec coil arcing
Old 01-21-2011, 01:38 AM
rocklobster87's Avatar
Default 97 vtec coil arcing
Lookin for a little insight
My boss bought a 97 ex coupe 4 cyl VTEC from auction for a friends foster daughter to have as a first car. Upon inspection i discovered the car had, among other things, a blown head gasket, and repaired it. After reassembly, i was surprised to discover that with key on, engine NOT running, the coil is discharging, arcing to the distributor body to the tune of about once a second. Unplug the distributor, it ceases, unplug the vtec solenoid, it ceases, unplug crank/TDC sensor, it ceases. When cranking, it doesn't discharge at all. The head was stripped and shaved so the distributor was removed, but was never dropped/kicked etc. The car ran well before being torn down, despite having a blown head gasket. What could cause a coil to discharge without a crank trigger to open and close it's primary circuit? Any help appreciated.
Old 01-21-2011, 08:33 AM
Sounds like something in the ignition system is causing a ground out.Try
Removeing the distributor cap , Check the cap for worn or carbon-arced terminals inside the cap. Check the rotor also for wear. Check the cap for cracks. Good luck,Bobby
rednwhiterocket
12-14-2011 06:29 AM
millerc
08-05-2009 03:35 AM
semkruse
01-05-2009 04:15 PM
johnu773
06-26-2008 10:51 PM
fixdupaccord
10-24-2006 07:07 PM
Quick Reply: 97 vtec coil arcing
