changing front turn signal bulb on 92 accord
Old 03-13-2008 | 12:30 AM
mechaincal_nut's Avatar
Default changing front turn signal bulb on 92 accord
Hi all,
Just wanted to know what is the easist way to change the right front turning bulb on a 1992 honda accord. Looks like the bottom bolt or ellen screw that holds in the cover is difficult to reach. Seems it would be easier to take out the entire headlight housing assembly then remove the blinker lens. Please provide a easy solution.
Thanks.
Old 03-13-2008 | 04:25 AM
Default RE: changing front turn signal bulb on 92 accord
Aloha mechaincal_nut: welcome the forum, enjoy your stay. You are correct on the first method, take the lenses off the front. Go to http://autozone.com sign in for free and go to repair, to 92, honda, accord, chassic electrical, headlight etc, and it will show you the drawings and info to r&r the lamp. If you get yourself a chilton, helms, or factory service manual (if you plan to save yourself a lot of $$$) They will show you how to fix just about everthing,
sbaker1973
06-06-2011 10:26 PM
tsmitherz21
01-17-2011 02:05 PM
vilfredo
03-07-2009 12:00 PM
broguearcher
03-06-2009 09:19 PM
broguearcher
02-25-2009 11:34 PM
