changing front turn signal bulb on 92 accord
Old Mar 12, 2008 | 11:30 PM
mechaincal_nut's Avatar
Default changing front turn signal bulb on 92 accord
Hi all,
Just wanted to know what is the easist way to change the right front turning bulb on a 1992 honda accord. Looks like the bottom bolt or ellen screw that holds in the cover is difficult to reach. Seems it would be easier to take out the entire headlight housing assembly then remove the blinker lens. Please provide a easy solution.
Thanks.
Old Mar 13, 2008 | 03:25 AM
Default RE: changing front turn signal bulb on 92 accord
Aloha mechaincal_nut: welcome the forum, enjoy your stay. You are correct on the first method, take the lenses off the front. Go to http://autozone.com sign in for free and go to repair, to 92, honda, accord, chassic electrical, headlight etc, and it will show you the drawings and info to r&r the lamp. If you get yourself a chilton, helms, or factory service manual (if you plan to save yourself a lot of $$$) They will show you how to fix just about everthing,
sbaker1973
Jun 6, 2011 09:26 PM
tsmitherz21
Jan 17, 2011 01:05 PM
vilfredo
Mar 7, 2009 11:00 AM
broguearcher
Mar 6, 2009 08:19 PM
broguearcher
Feb 25, 2009 10:34 PM
