Door Lock Troubleshooting
I have a 2005 Accord that had a "stuck" passenger door. The exterior and interior handles would not open the door. The lock **** was being actuated from both the driver and passenger side controls, but I couldn't get the door to open.
I was able to get the panel off from the inside and after fumbling around inside near the latch mechanism, I was able to unlock the door.
I need to figure out what was causing this problem so that I can be sure to replace the right part.
The interior and exterior handles are both connected to the latch and are "moving" it, so it seems like the cables/rods are attached.
I manually closed the latch mechanism using a screwdriver and when I tried to open it using the door handle, it would not release the latch.
Is it safe to assume that this is a bad latch mechanism?
