ENGINE CHECK LIGHT IS BACK P0420
Old Dec 22, 2007 | 12:57 PM
BOUNTY's Avatar
Default ENGINE CHECK LIGHT IS BACK P0420
Hello, I have a Honda Accord LX 4 cyl. 1999 and I changed the o2 sensor by the manifold (before the catalytic converter) because the code reader from Autozone says "catalytic system below treshold bank 1 " something like that.
So I was told to change the sensor by the manifold.
well, the check engine light is back. yes, I erased the code and disconnected the battery.
Any idea or similar problem???
Thanks
Bounty
Old Dec 23, 2007 | 08:46 AM
Default RE: ENGINE CHECK LIGHT IS BACK P0420
Aloha BOUNTY welcome to the forum. Have read many sensor problem like yours, I have been advised that if you put in anything other than a factory honda o2 sensor, that at times the light will return.This was even when it was found out that Honda uses the same type of sensor.
fyah17
Dec 22, 2012 03:03 PM
lkelley_s2000
Jun 7, 2010 09:09 PM
samuel_gatech
Nov 4, 2009 04:46 AM
