Engine idle smooth, but rough when stepping on the gas
Old Apr 24, 2018 | 07:55 AM
FL-Honda's Avatar
Default Engine idle smooth, but rough when stepping on the gas
Coming from a stop, and as the car started to accelerate, I heard a quick and brief sound coming from engine , it sounded almost like engine "dieseling", then I started to feel the car is not responding well to the gas paddle(it continue to accelerate but very slowly), car speed reduced to about 30-40 mph with a full throttle, all gauges are good, no engine check light. Within about 4 miles, the car traveling speed came to less than 10 mph, and I started to smell burning oil. When I opened the hood, I can some oil leaks coming from the head gasket cover dripping on the manifold. However, the engine sounds normal and smooth at idle (around 900 rpm), Temp gauge is normal. Also Gear shifter is locked, and still no engine check light.
Any suggestion is appreciated.
Thanks
File Type: avi
Old Apr 24, 2018 | 10:34 PM
welcome to the forum Possible cat clogged up.
Konig_13
Dec 16, 2009 03:02 AM
StevieD03
Jun 13, 2008 02:04 PM
herecometheazn
Sep 7, 2007 02:13 AM
hondafied
Mar 17, 2007 01:49 PM
