flushing coolant
I have a 2000 4cyl. Accord and want to flush and replace hoses,do you have to bleed the air from the system afterward? also want to do a tune up what plugs do you guys recommend?
it is located on the thermostate case. Go to hondaautomotiveparts.com and dial in your car, go to water pump sensor and you will see the picture and part and #12 called the breathing bolt. Funny name for a water bleed
Easy find ,thanks acmech52,was going to change the belts also but after buying them I took a look at the originals and the looked new so I threw the replacements in the trunk for safe keeping.
