h22 swap
Old Feb 24, 2015 | 10:58 PM
kinghaze's Avatar
Default h22 swap
I really need help woth this. I swapped a jdm h22 into a cb7. I used the vtec 94 accord harness. Everything came on fine. I turned the car on 5 sec later it turned off. I cant figure out why its been with someone whos familiar with swaps for months now and he has done nothing. We know it's getting no spark. He says its not getting enough voltage to distributor. Its a new distributor. He says all the grounds are fine and that somewhere its an electrical connection. He also said its asking for a crank sensor and that the jdm motor doesnt have it. And since i used the stock car harness its trying to read that. And it could be that. I dont believe its any of this i believe its something so simple but im not good with electrical stuff so idk. Any ideas? Also if this helps I had accidentally turned it on with the cb7 ignition wires. And then after that i tried those wires on a stock cb7 and misfire happened. Could putting the wrong wires caused something to go bad? Anything will help i spent a ton of money done want to give up. Pleaaase!! Thanks in advance
JAVID_ej1
Jul 9, 2009 06:53 PM
zapneylon
Oct 23, 2008 08:30 PM
Corbuston
Jan 18, 2007 11:00 PM
biggiesteves
Jan 12, 2007 01:42 AM
AsianJin
Sep 25, 2006 10:38 AM
