Headlight Not working
Old Jan 16, 2010 | 02:49 PM
hobbyfarmer's Avatar
Default Headlight Not working
I have a 1996 Honda Accord.
The driverside low beam is not working. Here's what I have done so far
Changed bulb - didn't work
Checked socket - didn't work
Checked wire in front of socket - no power
I did check everything on the passenger side as stated above and that all work.
What is the next thing I should check.
Old Jan 16, 2010 | 11:16 PM
91haydenSI's Avatar
check your fuses.. i know its sounds dumb but sometimes hondas have seperate fuses for each headlight.. i know mine does
Old Jan 17, 2010 | 08:34 AM
I checked the fuses - even switched the fuses between left and right and the problem still persists
Old Jan 17, 2010 | 01:08 PM
matimar30's Avatar
Member
if you already checked the fuses and still no light. then checked the power lines then the next step is to check the relays then the switch itself. what a major pain. sometimes it's easier to just buy an external switch and wire it in but you don't have that nice stock look.
Old Jan 17, 2010 | 02:11 PM
Would a relay affect only 1 low beam? Is the power lines different than the wire in front of the socket(I checked - no power)? Where do I find the relays?
Thanks for the reply
Old Jan 17, 2010 | 11:56 PM
matimar30's Avatar
Member
my chilton only coverys 84-95. you could go to a dealership and they can print out a blowout of parts for you including a wiring diagram. good way to check. relays are either near the fuse panel inside the car our in the engine compartment. i only hondas i ever worked on were 87 and 93 accords.
the problem you're having is for some reason or another there is no power going to to one of your head lights. you have to track it down. use one of those probes with a 12v light bulb to track down the wires. very time consuming. are you sure you checked the fuse? make sure is fully seated and dielectric grease is your friend.
good luck.
Old Jan 28, 2010 | 04:58 PM
Aspicle09's Avatar
If you two power outlets are not functional, then its highly likely to be the fuse.Which fuses did you check and where are they located?
Old Jan 29, 2010 | 10:12 AM
This is strange ,let us know what you find.
fishy21
Mar 6, 2015 01:55 PM
pwnnoobz
Jan 13, 2011 09:35 PM
palomino
Sep 28, 2009 09:34 PM
treyshonda
Nov 9, 2007 03:39 AM
jack_spicer
Aug 18, 2006 12:46 PM
