help asap
I have a 97 honda accord se with the engine HONDA ACCORD L4-2156cc 2.2L F/I Vin F22B2 16V SOHC ID#18585 okay and im looking to buy a 91 prelude im not sure wich engine it has its either the HONDA PRELUDE L4-1958cc 2.0L F/I Vin B20A5 16V DOHC ID#11972 or the
- HONDA PRELUDE L4-2056cc 2.1L F/I Vin B21A1 EFI DOHC ID#18284 my motor in my honda is great and so is the tranny the only problem with my car is that its totaled because of frame damage and i was curious to find out if my engine would fit in a 91 honda prelude!! please help! Otherwise i have to sell my car for parts.. |
RE: help asap
Part the car out get the money and just go get the H22 and put that in the Prelude that H22 will piss all over that F22b2.
I have a 94 accord with a F22b and everyone trys to get me to put the H22 to in it. but i will come to that crossroad when i blow the motor. hope that helps some |
RE: help asap
As far as I know, yes, your motor will swap. I know that honda accords and preludes between 91-97 have pretty similar engine compartment size and setup. You will probably need to move around tranny mounts and get a different ecu/wiring harness, but the swap should be possible. I would hook up with someone thats done the swap before. You dont want to attempt one alone unless you have the equipment and a knowledgeable helper. Good luck! The H22 is a great motor though. Definitely check into that if its an option for you. Its probably the MOST common swap for accords and most desired motor in the preludes.
RE: help asap
you are not going to want the earlier prelude motors. those motors require a different way of mounting. they have what some call a "gangster lean" because of the pitch of the engine. the h22 is a great motor to swap in.
