Honda accord 7th geneartion
If code says knock sensor then usually means the sensor or the wiring has an issue.
Sometimes connector pins have fitment issues. Other times, corrosion. Grounds.
Sorry, this is all I can offer with the limited information I have.
after market sensor may look the same and so will the wires but they are not built for Honda cars. Honda asked the same manufacture to build the same type sensor using the honda specs so some will work but for a short time.
