Interior lights and windows not working
Old Oct 11, 2010 | 09:29 AM
skifreak's Avatar
Default Interior lights and windows not working
I have a 97 Accord SE that I just bought. Here is a list of what is NOT working and I looked at the fuses and they all seem ok. I have electric locks and windows
-- Driver door
passenger window
both rear windows
dome light (works on every other door)
-- Rear doors
windows
Any help is greatly appreciated.
Mark
Old Oct 11, 2010 | 10:30 PM
xmechanic's Avatar
Does the passenger door window work from passenger side window switch? If not, take a look at the master window lock-out switch. Dome light not working when opening drivers door is most likely the door switch in the door jam. Try swapping it with the passenger one to see if it works with that one.
Old Oct 12, 2010 | 04:53 AM
skifreak's Avatar
Thanks.. I will give those a try..
Old Oct 18, 2010 | 09:34 AM
I just had an issue with my truck the window switch worked from the master control but not always from the passenger door,took off the door panel and the switch worked everytime,come to find out the wiring in the bundle had a short ,seems impossible but it did,check you wiring good,with the power on try the switch and wiggle the wires.
Old Oct 18, 2010 | 04:09 PM
skifreak's Avatar
I will look at that as well. Heading off to vacation.. Will post when I get a chance to look at it
JennyBoo311
Mar 4, 2021 07:06 PM
dkm2
Oct 31, 2011 06:21 AM
ras282
Mar 16, 2010 09:31 AM
micmoor
Jul 13, 2009 08:53 AM
ilsalk
Nov 2, 2008 11:45 PM
