K24 swapped 95 accord help
Old Oct 18, 2020 | 01:08 PM
Brigham Robins's Avatar
Default K24 swapped 95 accord help
If anyone has done a k24 swap into a 95 accord I am wanting to do the same and am curious what additional things would be needed to make this work, or would the engine simply just fit and plug in. Thanks in advance
Old Oct 19, 2020 | 06:49 PM
i have never swapped a k24 in an accord, but here are some things to think about. you will need the accord front frame to adapt to the front of your 95, the wire harness of the k24 needs to blend into the plugs to the 95, the k24 ecm will need to be piggy backed into the 95 ecm, your exhaust headers may need to be built or find one that fits into your accord, yor need to check the height of the engine to make sure it will fit properly, and if you're in Ca. you will need to get a special smog cert for the car. make sure you have the bill of sale for the the k24 if you decide to purchase it, or how you obtained the parts. When i wanted to mod my Honda Fit to the K2.0 300hp, i looked into sending my car to Mugan to do the mod in Phonix Az. at the time, it was about 5k to7k do the mod but being in Ca, i would have to do a lot to get the smog approved for such a huge engine. if you look up in google, you may find a few books on how to do an engine mod such as yours. good luck. Big Bucks $$$$.
HondaGypsy
Jun 11, 2016 08:37 AM
john917v
Sep 18, 2010 01:18 PM
biglfla
Aug 12, 2010 10:18 AM
Honda_JD
Oct 11, 2009 09:52 PM
Darkace
Sep 2, 2006 05:44 PM
