Keyless Entry + Dome Light
Old Dec 16, 2013 | 05:48 PM
sleepyj's Avatar
Default Keyless Entry + Dome Light
Hi all, I did a quick search through the forums and couldn't find anything on this, though I'm sure this is a problem someone has come across before.
I'm troubleshooting an electrical problem with my 2002 Honda Accord. At the moment I'm without 2 things, my keyless entry, and my automatic dome light setting. My dome light works but will not come on automatically when it is in the proper setting, middle, and my doors are opened. My keyless entry isn't working.
The clue I have to work with is that when I turn on my headlights, both work fine again. Dome light comes on when the door is open, keyless entry works.
I've checked all the fuses on the left and right of the car, I'm going to continue checking the fuses under the hood of the car.
If you guys have any tips, I'd really appreciate it.
thanks,
j
Old Dec 19, 2013 | 07:12 PM
joeywor's Avatar
Arrow
Try locking and unlocking the door with the key and also check if the key in the door will put the windows up and down. It may just need reset.
Old Jan 17, 2014 | 01:08 PM
phae_drus2004's Avatar
Reset with a battery disconnect and connect may help...
Old Jan 17, 2014 | 07:14 PM
To reset the keyless,put key in ignition turn to on position 2 press lock and unlock on key fob turn the key off. Do this three times ,the dome light may be connected to this reprogram.
89Accordlover
Aug 10, 2012 10:47 PM
mediagirl
Jul 15, 2010 04:53 AM
Donkeydawn11
Apr 28, 2010 03:05 AM
89hondacrx
Feb 22, 2010 05:35 PM
highwayman
Mar 15, 2007 11:41 AM
