Moderate tumble/wobble at Hwy/Interstate Speeds
Old Jun 2, 2024 | 06:44 PM
jarrettmonty's Avatar
Default Moderate tumble/wobble at Hwy/Interstate Speeds
I have a 2014 Accord Sport. For the past couple years I've been getting a rumble(felt in the car but also in the steering wheel a tad) when hitting anything from 60-80. Initially it was truly just unevenly worn tires. Got them replaced, balanced. Worked for a bit (but then my I started feeling a rumble when applying the brakes at these speeds?? But has since resolved), but eventually started again. Got a rotation and balance, barely helped. And so on.
I've went to 3 different shops, had maybe 6 different tires, and nobody has been able to diagnose anything other my tires being out of whack (they usually are), but it definitely seems to be a symptom, not the cause.
​​​​​​I've had a minorish accident, hitting a median curb, at a big *** storm drain opening. Was told the tie rod was bent, and fixed, and I had no issues for at least 3 years, so not sure that's totally relevant.
Just curious if anyone's had a similar issue
Old Jun 6, 2024 | 06:55 PM
welcome to the forum. have you ever had a 4 wheel alignment done? When were your brake disc replaced, front, rear.
Old Jul 2, 2024 | 04:58 PM
pj.d105accord's Avatar
Hey Guys,
Im having same issue with my 05 Accord coupe
Just had rack and pinion gearbox replaced upper control arm and a four-wheel alignment and my car still sways to the left and right along with my steering wheel at 50 to 70 mph and I can't figure it out
remtx79
Jul 27, 2023 05:56 PM
Nash123
Jun 8, 2022 12:09 PM
LaC0saNostra
Jul 17, 2015 08:23 AM
tko04
Jun 5, 2010 02:48 AM
GreginLA
Jun 22, 2008 06:11 PM
