multi dash warning lights
Old Jul 15, 2019 | 11:10 AM
humblebuckeye's Avatar
Default multi dash warning lights
I don't drive my 2013 Accord EX 4 cyl often. I started it a couple days ago and it has multiple dash lights on. They are electric steering, low tire pressure, stability control, forward collision, lane departure, and ABS. It seems to drive fine. I'm assuming that it's a simple, related issue.
Old Jul 15, 2019 | 10:54 PM
welcome to the forum. have you tried shut down and restart, also shut down disconnect the battery and resecure the terminal, be aware you'll need your radio code to get the radio to work again.
Old Jul 16, 2019 | 04:27 PM
Default Shut down
I drove it then and a couple days later a second time. No change. Have not disconnected the battery.
Old Jul 17, 2019 | 06:06 PM
Do disconnect the battery,it acts like a reboot on a computer.
Old Jul 17, 2019 | 09:54 PM
Make sure to clean the battery terminals and cable terminals.
Electronics goes nuts if the power and voltage going to them is not what they expect
Weird things happen.
Old Jul 18, 2019 | 01:04 AM
I'll give it a try
Old Jul 24, 2019 | 11:59 AM
Disconnected the battery and no change
Old Jul 24, 2019 | 06:43 PM
if you can get a hold of a scan tool, or go to an auto zone, clear all the lights, start fresh.
Old Jul 24, 2019 | 08:54 PM
Check all your fuses and relays
Old Aug 1, 2019 | 09:18 AM
  #10
Autozone scan showed nothing. Alternator showed good at 14.4. After I went to autozone I washed it. When I left the car wash the lights went out but later came back on.
