Need help removing alternator
Old Oct 2, 2006 | 08:26 PM
Gardensnake's Avatar
Default Need help removing alternator
Hello,
I was wondering if anyone has had any experiance removing an alternator from an '85 Accord. I'm trying to change the alternator and can't get the old one out. I've gotten it completely unhooked but it won't clear anywhere I try. Any help would be appreciated.
Thanks,
William
Old Nov 12, 2006 | 08:54 PM
SOKal's Avatar
Default RE: Need help removing alternator
William,
Not sure if you got any response before now. I just joined the forum and ran across yours. Mine is 1990 Accord. Recently I had to take all that stuff off of mine to clear the cross member to lower the engine in order to replace the harmonic balancer. I had to take the alternator bracket off the engine in order for it to clear. I don't think you should have had to do that, however. It should merely pull straight up from the engine mount clearing the radiator.
Let me know if you had any luck prior to this and how you did it.
Scott
Old Nov 19, 2006 | 02:22 PM
djglazed's Avatar
loosen your mount bolts.go under car loosen subframe bolts take front left wheel offtake big pry bar stick against firm place pry against motor it willgive you just enough room to clear it .keep in mind you must have 2 people to perform this suggestion good luck
thomasdean932
Feb 27, 2014 06:04 AM
Gorillamo
Sep 30, 2013 09:09 AM
SlowCoder
Oct 31, 2009 03:02 PM
hondavato
Sep 2, 2009 02:09 AM
chrisn82
Jul 2, 2009 02:10 AM
