need some advice regarding PS pump
Old Nov 10, 2008 | 01:42 AM
mike0094's Avatar
Member
Default need some advice regarding PS pump
i just want to know if old power steering fluid can eventuallydamage a power steering pump? i have a strange grinding/whiriling noise that comes from around the timing belt and ps pump area, some people say the belts are too tight, others say its my ps pump. If i change my fluid, might this fix the noise? i dont think the fluid has ever been changed (120,000 miles)
Old Nov 10, 2008 | 08:35 PM
Default RE: need some advice regarding PS pump
oils do not loose their lubricating properties, they will carry worn metal or particles through out the system, so if your p/s pump is noisy, changing the fluid will not quiet it down,the pump will need changing at some time in the near future. If there is a thicker fluid that can be used for the pump, it may quiet it down a little but will make noise again. the pump blades are worn.
92 honda civic hatchback
Aug 22, 2010 11:23 PM
Shpook
May 26, 2009 12:04 AM
B.Anderson
Mar 6, 2009 03:24 PM
honda05chick
Oct 21, 2008 02:04 PM
kerry400f
Jun 12, 2008 07:00 AM
