oil consumption
Old Apr 22, 2022 | 10:24 AM
hondaaj5's Avatar
Default oil consumption
2000 honda accord ex 2.3 ivtec sohc. 72,000 miles. burns ALOT of oil. i changed the oil and it is immediately black. I checked the pcv valve for a vacuum leak, and it checked out. there is a lot of black soot in the tailpipe. i am in the automotive industry and am leaning towards rings and valves? but the car runs SO good. i mean you can feel the vtec engage and disengage. any thoughts?
Old Apr 22, 2022 | 11:55 AM
I believe you are right ... rings and valves
Would do the simple stuff first.
Check the valve clearances
Old Apr 22, 2022 | 12:07 PM
hondaaj5's Avatar
i would think it would have some sort of driveability issues? i just can't really justify doing the repair on it... i do not understand why i literately put oil in it, start it up, and it is black.
Old Apr 22, 2022 | 12:29 PM
You should replace the PCV with OEM before doing anything else.
Also, Do you have oil in the intake?
Old Apr 22, 2022 | 12:30 PM
hondaaj5's Avatar
why? not discrediting. just curious. it seems to be functioning
Old Apr 22, 2022 | 12:33 PM
Seems to be functioning is not a valid test. They are cheap and easy to replace and a bad one will cause problems like you have.
Until you do replace it you won't know. You could rebuild that engine and it may not burn any less oil than it does now.
Old Apr 22, 2022 | 02:43 PM
hondaaj5's Avatar
there is no oil in the intake. but the tail pipe is black. it is not oily, but very thick soot
Old Apr 22, 2022 | 02:44 PM
hondaaj5's Avatar
agreed. I will get an OE valve
Old Apr 22, 2022 | 02:55 PM
How much oil in 1000 miles? Did this happen suddenly? Is there oil leaking from the engine?
Old Apr 22, 2022 | 04:28 PM
  #10
hondaaj5's Avatar
depends on my kind of driving. if its higher rpm's on the highway it burns quicker. if it is just around town maybe 1.5 quarts. but more on the highway. I have not owned the car but a couple months. it is in perfect shape other than this. no leaks, etc.it does stump me that it is all of the time pitch black.
