p38 tires
Old Oct 23, 2009 | 05:34 PM
D.hieme's Avatar
Default p38 tires
Hello everybody,
It time for new tiers for my p38, if you can recommend on a type or where to buy?
another question: whats the max size that can be installed without modification?
thanks
ROY.
Old Oct 23, 2009 | 10:22 PM
matimar30's Avatar
Member
stock rims? you can normally go with a size wider. but you if go aftermarket than you have a lot more options. if you take it to a good shop then they'll check your wheel wells and max out without scrubbing. if you go this route they might have to modify whatever hardware or computer to keep your speedo accurate.
i personally like to have my car lowered, wide as possible and with 40 profile tires. it's in the middle between performance and bumps from those dame pot holes on the road. if you go to low then open your wallet for another rim.
Old Nov 3, 2009 | 08:52 AM
You can safely go over one size,I went over two sizes on my Vette and the tire has a slight bulge,so next tire change I will go back one size.
ss96dcm
Sep 16, 2006 01:24 PM
abright52
Sep 9, 2006 05:56 PM
gp99sami88
Aug 25, 2006 02:18 AM
hlalnls
Aug 20, 2006 12:11 AM
malioris
Jul 13, 2006 09:19 AM
