power steering fluid problem??
Old Oct 12, 2008 | 11:20 PM
mike0094's Avatar
Member
Default power steering fluid problem??
i got a 94 accord and i checked my PS fluid the other day and the level was fine but the smell of the stuff was so horrible i couldnt stand to smell it for more than 5 seconds..is it supposed to smell so bad? maybe my fluid is worn..do i have to change it? i dont have any problems with the power steering system by the way, any one got the same problem?
Old Oct 16, 2008 | 07:36 AM
Default RE: power steering fluid problem??
welcome to the forum, the p/s fluid should not smell so bad, I got some from Honda Parts and replaced my fluid and it smells ok. I have my fluid changed when they change my trans fluid each 30k. might want to change yours soon.
Old Oct 18, 2008 | 06:47 AM
mike0094's Avatar
Member
Thanks for replying, how do u exactly change the p/s fluid, its probably simple and straight forward but i want to doitproperly.Do you simply suck the old fluid out of the bottle and refill it with new fluid? how did u change yours?
Old Oct 18, 2008 | 11:10 AM
I removed my return hose and placed an extension hose to drain out into an oil pan, and pluged the pipe with a hose plug and clamp, then had a friend start the car and I just added clean fluid through a funnel into the resovoir as it drained out into the oil pan. Caution not to overfill to quickly, it may get a bit messy.
papasloane
May 14, 2023 07:22 PM
m_mcgranahan
May 30, 2012 10:51 AM
golfer1512
Aug 26, 2009 07:14 PM
gtrplr2
Nov 14, 2008 03:22 AM
HondaCivicCX
Jan 6, 2007 05:31 PM
