R&R cylinder head
Old Apr 28, 2009 | 09:14 AM
dodgensince74's Avatar
Default R&R cylinder head
How hard and long does it take to R&R the cylinder head on a 97 Accord with the 4cyl non vtec?
My girlfriends car over heated on her the other night when a small water hose at the back of the engine blew on her. The car is running good now, but it is now blowing air bubbles into the over flow bottle but no water is mixing into the oil so I am thinking maybe a bad head gasket or cracked head, she is only loosing about pint to a quart of water when it is driven 30 to 50 miles and not getting hot at all. Thanks for your help in advance.
Old Apr 29, 2009 | 05:33 AM
flate rate shows 6 hrs to remove and reinstall the cylinder head
Old May 13, 2009 | 10:51 PM
does any one know of any good sites where it shows how to R&R the head on this car? I took it in and the shop said it was the head gasket but they only wanted to replace the whole engine not just the gasket or head so I figure I would just do it, this will be my first time on a small car.
Old May 14, 2009 | 04:02 PM
when you replace your head gasket, get your head shaved to prevent the gasket from blowing out again. Go to HondaHookUp.com. register and I beleive I saw a service manual you can download. I would highly recommend that you perchase a factory service manual, cd or hardcopy will help you better.
Old May 14, 2009 | 08:33 PM
thanks for the info, will have to go there and check it out, thanks again
madscientist
Feb 7, 2013 01:34 AM
manual94accordlx
Dec 20, 2011 03:51 PM
HONDASHOW
Nov 23, 2011 12:16 AM
waxontherun
Aug 23, 2009 10:46 PM
