Water Pump after 43,000 miles?
I am using my mom's (original owner) 2000 V6 Accord with 43,000 miles and am suspecting the water pump is leaking. The antifreeze level is up and it wouldn't leak under the pressure test. The mechanic sees stains down the timing belt cover and when the car sits I see antifreeze(dirty) on the floor. Isn't this kind of unusual to happen after such low mileage? He thinks so too and wants me to keep an eye on it. I'm leaning to the water pump regardless. I was quoted for the water pump, timing belt, and cam seals $600. I know the belts don't get changed to around 90,000 miles and I may not be keeping this car for much longer (my mom is 87). What would be a good price to change the water pump? Can I drive for much longer without changing it? Thanks all.
RE: Water Pump after 43,000 miles?
Aloha Bocatrip: Welcome to the forum, enjoy your stay, and hope we can all assist you. Antifreeze is good for about 2 years in the car, the car being a 2000 is 7 years old, the anti-freeze should have been changed 3 times, and the oil each 6 months or 3-5k miles. Car has low milage but oil and antifreeze should be replaced at time intervals due to milage is low. View this for antifreeze info http://en.wikipedia.org/wiki/Antifreeze, Also oil info may be in here also.
I have a neighbor that does all my heavy maintenance for my 02 civic, he says its about 350.00 plus parts to change the belt, water pump, cam seal, crank seal,on a 4 cyl accord at the shop. Your car is out of warrenty unless you have an extended warrenty ( idea to purchase if keeping the car) before you get it fixed. Honda shop is more expensive to fix the waterpump/timing belt, etc.
The actually place that had the leak was the bottom of the upper rt engine mount. There are 2 bolts underneath where I saw a brownish fluid for a few days. I cleaned the bolts up under the mount and noticed the fluid again the next day. Eventually, it stopped all together. Does that mount have fluid? Was that the problem all along? Can that mount work fine without fluid?
I am not aware of any mounts that have fluid in them, there may be a possibility of the fluid running down from the leak to the mount. I'll need to do some research to see where the fluid area is to the mount. And I beleive your v-6 has a timing chain, not a belt.
ORIGINAL: acmech52
you are correct on timing belt, viewed in Majestic Honda.com parts manual does showa belt. Also found that the v-6 has two electronically controlled (active) engine mounts and a side stopper mount with a (passive) hydraulic bushing to hlep minimize engine vibration on v-6 models. found in http://corporate.honda.com/press/art...20010221001316 the leak you found could be from the hydraulic bushing.
ORIGINAL: acmech52
atikovi
05-10-2009 08:43 PM
04 allroad
03-09-2009 08:21 PM
sandyg645
10-20-2008 06:19 AM
