Wiper arm problem
Old Oct 23, 2012 | 05:39 AM
blackie52's Avatar
Default Wiper arm problem
Hi: I noticed my accord driver side (26") does'nt make contact fully on windshield. There is a area 4" wide with little or no contact. I have changed the wiper blades 2 or 3 times, each time buying better grade blades. I'm thinking the spring under arm is a little worn. Anyone with this problem. Thanks
Old Oct 23, 2012 | 12:50 PM
lowlife9's Avatar
it could be a worn spring or the arm could be warped or the tip bent also make sure the nut or bolt holding the arm on is tightened properly. did it just start doing this or did you buy it like that ???.what year is your accord??? if all else fails you can buy a brand new wiper arm here for around 50 dollars also contact a dealer it mite be cheaper to pick it up yourself. http://www.hondaautomotiveparts.com/...artsSearch.jsp
Old Oct 23, 2012 | 05:58 PM
blackie52's Avatar
Thanks for the response. The problem start slowly over a couple of months. thinking the wiper blades were too much of a bargain & not doing there job. I will have to look at the oblivous things as you seggested.
Old Oct 24, 2012 | 10:01 AM
Flip open the plastic snap cover at the bottom of the wiper arm using a small angled pry bar or a straight-edged screwdriver.
Size up the nut under the snap cover with a 3/8-inch drive socket and loosen with ratchet. Remove nut.
use the screwdriver or pry bar to gently but forcefully lift the wiper arm off of the spindled arbor.
Hold the wiper arm just above the spindled arbor and reinsert in the position that you want it to be when it is in the "off" position.
Re-tighten the nut. Turn the key in the ignition and test the wiper arm to make sure it's swiping the windshield properly. If not, adjust as needed until the desired position is achieved. Repeat the procedure on the other wiper arm, if necessary. Make sure to snap the cover back down onto the wiper arm nut.
joe
Feb 3, 2018 04:36 AM
sferrie
Feb 24, 2012 09:26 AM
wendee008
Mar 20, 2011 09:10 AM
91Honda
Nov 4, 2010 12:40 PM
papic03
Jul 6, 2007 08:23 PM
