Wiper issue
Old Sep 22, 2010 | 01:16 PM
cvanderhoef's Avatar
Default Wiper issue
Hi all, the wiper on the driver's side won't stay down (touching the glass). I can push the wiper down so that it touches the glass but when I use the wipers the wiper comes off the glass. Any ideas on why this is happening and a fix? Thanks.
Old Sep 22, 2010 | 10:41 PM
sean62's Avatar
I would suggest you to check the car's manual.there it would be given why such thing is happening.
Old Sep 23, 2010 | 03:30 AM
have you checked to see if the nut holding the wiper blade down is loose.
Old Sep 23, 2010 | 07:42 AM
I'll check the manual but I'm sure it won't be listed in there. I have checked nut and it was tight but I'll check that again to be sure.
Old Sep 24, 2010 | 07:54 AM
Rechecked the nut and it is tight. Haven't checked the manual yet.
Old Sep 25, 2010 | 03:35 AM
did you check to see if the spring tension on the wiper is good, sometimes it gets weak or breaks.
Old Sep 26, 2010 | 07:12 AM
Nope didn't do that. What's the best way of testing the tension of the spring? Thanks.
Old Oct 1, 2010 | 10:54 AM
Check the tension on the other side It should be the same ,if not try getting another arm.
dog_ear
Dec 17, 2012 08:43 PM
wendee008
Mar 20, 2011 09:10 AM
Dlygamtrupfar
Jan 21, 2010 02:35 PM
Mills
Aug 28, 2007 07:57 PM
wylee00
Jul 23, 2007 03:21 PM
