2003 Civic Hybrid Transmission Problem?
![Default](/forum/images/icons/icon1.gif)
Hello. I have a 2003 Honda Civic Hybrid. It has a CVT transmission and I am having some problems that make me think I have some major transmission issues going on.
First, about a year ago when driving through parking lots or anywhere at very low speed, the car would sort of jump or lurch forward. I have an Audi A4 with a CVT transmission as well that had to be replaced, and this feeling felt almost identical to when the CVT transmission in the Audi was slipping. It wasn't getting worse, so I wrote it off as a design problem rather than a failing part. Perhaps I shouldn't have.
Last week, I was driving home and out of nowhere the car started violently shaking when I was under 30MPH. The shaking felt as if the transmission was slipping. I made it home, and parked in the driveway. I started investigating what the issue could be. The transmission fluid level was normal and everything seemed in working order. The problem definitely wasn't an engine problem, but a drive train issue.
When I got back in the car to pull forward into the garage, I put the car in drive and accelerated as you would normally to go forward on almost flat ground. When I did that, it was like the car was in neutral. Hitting the accelerator only revved the engine, but when releasing the brake the car only rolled backwards down the driveway. We finally had to push my car into the garage.
A few comments:
1) The check engine light is now on. I don't have an ODB-II scanner for the Honda, only Audi-specific software. I'm going to try to pull the codes to see what that is about.
2) The service guidelines have been followed. We changed the transmission fluid last summer and used fluid from the dealership for this specific car and transmission type.
3) The car has about 115,000 miles.
I've searched the forums and haven't found much about this specific issue. Does anyone have any thoughts on this? Very bizarre...
-Chris
A few comments:
-Chris
Munkhuu Saikh
12-06-2015 12:39 AM
stephshonda
08-11-2015 04:32 PM
jksharp
12-02-2008 10:33 AM
atikovi
03-27-2007 12:43 AM
