2009 Civic
Old May 11, 2023 | 07:49 AM
Shrek's Avatar
Default 2009 Civic
This issue is consistent , easily duplicated . When problem happens, there is little to no response from gas pedal. It doesn’t run rough , idle is lower but not dying low . Press pedal rpm’s do not change . Pullover and shut off car. Restarted car and problem is now gone . So restarting car seems to solve the issue. Check engine light shows all 4 cylinder misfire codes. Pulled coils, replaced plugs and adjusted valves . Test drive and issue still there, but can be “repaired” by cycling ignition . Waiting for my fuel adapters to check pressures, have not done that yet. Looking for some direction. Misfire codes with no real misfire occurring. Fresh gas has also been completed .
Old May 11, 2023 | 08:22 AM
What kind of scan tool do you have? Need to look at some live data.
Old May 11, 2023 | 10:53 AM
Shrek's Avatar
Appreciate response ,Triton d10. I watched some items but wasn’t seeing anything that led me to a smoking gun. This scanner is new to me, working on my skills with it . I am open to suggestions on what to watch ? The fact I can eliminate the condition by a restart is what I really tripped over .
Old May 11, 2023 | 02:57 PM
Can you post the freeze frame data?
Old May 11, 2023 | 04:17 PM
Shrek's Avatar
I return to work tomorrow I will post relevant data .
Old Jun 18, 2023 | 05:57 PM
Shrek's Avatar
Default Fixed
6/18….. wanted to close this out . The fact that restarting the car fixed the problem I leaned more to the electronic side . The ECU was only $50 on eBay so I took a chance . Immobilizer Data aligned and problem solved . Appreciate the responses to my repair .
RBrooks828
Mar 8, 2020 06:35 PM
Miyisha92
Dec 21, 2016 08:04 PM
cutlas
Jan 23, 2016 06:08 AM
brikcity
Jan 9, 2009 04:32 AM
billybop45
Mar 19, 2008 03:01 AM
